Since yesterday I can’t add a new view of a synced table.
Instead of adding a view it tries to sync again
Dear @Thomas_Schulz,
I just made a quick test, at my end it works fine.
Rather sure that you did all the basic routines in such case (restart computer, empty history of browser, check out if the problem exists also in an other doc.
So, I think you will need support from a Codan that can be reached out either on Intercom ("?") or at support.coda.io
The community will appreciate if you could report back any relevant info on what caused the issue or did you do to solve
Thanks @Jean_Pierre_Traets did the basic routines already
I will check on another doc, good point. True: as the support is only US timezone, I thought I post it here on the community
Just made a complete new doc, same issue
Will ping the support later today
