When I do step 1 of the automation, it is pulling in the data from the display column as the Step 1 result, instead of getting the data from the column I specified. Is there some way to refresh the automations panel to get it working properly? Or is it a known bug?
Ok, so I just needed to use (Step 1 result).(column that changed) to get that info.
