That is my biggest issue as well. That feature is a must have.
@Lars_Kristian_Aasbrenn Please make sure to add this feedback in the feedback form as well
Best regards
Jannis
Best regards
Jannis
I concur too… sometimes majority the practical option is just the Group with UI presentation like a subtask. a more neater presentation.
I’ve now applied for the Beta three times, the first one shortly after it was announced. Have yet to see it activated on my account. Filled out the Beta form here but still nothing. Anyone else had this issue?
Has anyone figured out a means of displaying a table with subitems in a timeline view in any reasonably representative way? I’ve tried a few different ways but nothing seems to work.
I’m finding this incredibly frustrating, because if you need timeline views it seems you simply cannot use subitems until they’re added by Coda to the timeline view…or hopefully I’m missing something!?
Hello @Bell_Arden
The best approach I have found is to use grouping. In the timeline, I filtered all rows that have children and grouped the results using a third column.
However, this method is not very scalable since you need to set up a column for every level you want to group. Additionally, the visualization is not ideal when there are leaves at multiple levels.
In my case, every leaf is at level 2. So, for each leaf row, I have two parent levels, as shown in the image below.
This is my timeline view:
And this is my table view with subitems.
Even though “ME1,” “Reuniões,” and “Macroentrega ME1” are rows in the table, I filtered them out in the timeline visualization. I also have two columns that calculate the level 0 parent and level 1 parent, which are then used for grouping.
Best regards,
Arnhold
Thank @Felipe_Arnhold - This was basically where I arrived at - you can get it to work only if you only display items on the lowest level, which is what we already have with sub-tables, and thus severely limits the utility of sub-items if you need timeline views.
@Sam_Harper - Can you shed any light on subitems in the timeline view?
Hi Bell,
I’m Kathy, and I’ll be managing the subitems beta for the next few weeks as Sam is currently out.
Our team is actively working on supporting subitems in timeline views, ensuring that parents and subitems display in their proper hierarchy! This is expected to roll out in beta in the coming weeks. I’ll update this thread once it’s live. We appreciate your feedback and look forward to hearing more!
Cheers,
Kathy
Also waiting for a very long time… so excited for this feature!
Got it! Thanks Coda!
hello , still submitting my request since 6 weeks , however , i dint recived any invitaion to join Beta , looking forward for assist
Hi all! Big thank you to everyone who signed up, the response has been awesome. We’re pausing on enrolling any more beta sign ups to gather feedback and get ready for launching.
For those that are already in the beta, please keep the feedback coming. For everyone else, we’ll be sharing updates as we have them!
Hello Ashraf,
You should be all set up as of this morning. Let me know if I can be of any further assistance.
@Paul_Wilkins great efforts , YES , You and coda amazing team have done it ,
wish you a very good luck , its awesome update ,
also , i have to shout out to coda team for enabeling the group column doubling , to be free to used while the grouping feature is active,
great idea
love coda
Great to hear that’s on the list.
Any chance you’d enable sequential entries for that matter in the timeline view?
The hierarchical view of subitems will increase vertical space and vertical scrolling in the timeline even more
Bummed I missed the beta - any rough timeline for the full launch?
Hi Bell,
Following up to let you know that subitems are now supported in timeline views in the beta! Let us know what you think!
Hey @Kathy_Pan
Wow that’s great news, thank you!!
The layout looks great and presents exactly as I’d expect/hope.
There does seem to be a bug where the dependency links between items/rows aren’t showing. They are working, but the line is now being displayed. Hoping that’s a quick fix for the devs.
Thanks @Bell_Arden ! Would you mind filing that bug here along with a screenshot of what you’re seeing so we can investigate? Thanks!
It looks like in subtables it does not show the parent-subitems relationships. Unless this is something that needs to be activated manually?
I am facing the same issue.
To me, it seems that the dependency lines are misaligned, as if the parent rows are not being considered when calculating their positions.
I already submited the feedback with an image
EDIT:
I just noticed that this issue only occurs when the subitems are collapsed. If all subitems are expanded, the lines display correctly. With every collapse, the dependency lines shift vertically.
