Hi, I’d like to know if it’s possible to change the workspace admin without affecting anything in the current setup. We’d like to keep all integrations, automations, permissions, API connections, and document or workflow logic exactly as they are.
Can the admin change be made without disrupting access or breaking any existing functionality?
I would suggest using the question mark bottom right of the document to contact the support team.
