Charts: "Other" category for charts to account for rows not displayed
A great Coda feature is displaying a table as a chart. However, you rarely want to display every single row in the chart, as that would be very noisy. Currently, the advice is to add a filter. However, that skews the data, especially for pie charts. Depending on what is filtered out, the percentages of the pie shown are not true for the entire dataset.
This is a solved problem: charts usually lump everything that is not displayed into an “Other” category. However, this would require a different feature for filtering than just using the filter primitive. That may be a good thing, since charts (and tables in general) already need a feature to limit number of rows displayed without having to duplicate all view parameters in a filter, a pain point that comes up repeatedly:
So by introducing a separate feature for number of rows displayed could feed two birds with one scone.
Another way to do it would be to allow users to enter a formula for the Category displayed instead of a table column. This also feeds two birds with one scone, as it allows customizing chart labels on a case by case basis (it is not always pragmatic to have a separate column for every chart) and would make this possible too, as users can tweak when the formula returns “Other” as the category title.
