I’m trying to create basically a chatbot in Coda, but I notice that the automation time is quite long like 20-30 seconds just to send the data from coda to Make.com (from me tracking the seconds between when I start it and when make.com says the scenario began).
Make.com usually finished the relay back and forth between coda & openai in like 10 seconds.
This is along time to wait for a response.
When I first set this up, it wasn’t taking nearly as long.
Anyone know why the automations take so long sometimes? Is there any way to reduce that lag time?
Current setup: Form fill with an automation that activates on the form fill and triggers a button push in that row.
The button sends json data to make via webhook.
