Coda build-out for ppc agency?
Hi - Can you recommend a Coda expert with experience building out a setup for PPC agencies?
We are a rapidly growing ppc agency looking to use coda for internal task management as well as systematizing client communication.
Thank you for any feedback, and have a great weekend,
Ian
Hey @Ian_Nagy I might be able to help you. The grandmaster around here is @Paul_Danyliuk - you’d be lucky to get his help. DM either of us (or maybe we can both help if you have a lot of work).
Hahaha :joy: thanks for the mention @Johg_Ananda!
Frankly, I’ve never had a chance to build anything specifically for PPC agencies. But I do a lot of different Coda work for different clients and usually grasp their specific business needs pretty quickly.
BTW welcome to the community @Ian_Nagy !
Thanks you @Johg_Ananda & @Paul_Danyliuk for your responses :slight_smile:
I sent both of you messages on Linkedin (I couldn’t figure out how to DM you on this forum :sweat_smile:)
Hope we can connect soon.
Thanks again and have a great weekend,
Ian
Ian - click the user’s profile icon in the message thread and you will see the direct message option in the upper right of the dialog.
I also do a fair bit of Coda-related consulting, but I tend to focus on projects that involve process automation and integrations using Google Apps Script (which is to say not just about Google Apps) and smart documents that leverage data visualizations, AI, and machine learning.
