Coda Community Solutions Library
Hi all!
The following doc is a collection of community posts that provide various doc solutions. This is a great place to find some ideas for how to build out different things in your doc, or solve problems you’re running into.
What’s a solution?
Solutions can help us solve problems in our doc.
A solution…
  • Solves a problem in a doc
  • Gets you from Point A to Point B
  • Changes the nature/status of an element in the doc
In a nutshell, a solution is an answer to a problem you want to solve in your doc build.
This doc will be periodically reviewed and added to. If you have a solution you want to share with the rest of the community, be sure to add it here!
You will not believe this, but I was thinking five minutes ago that a solution/ topic/ discussion point option was something missing in the Coda community!
Codans reading minds now too?
You have inspired me to get back to my Formula Reference Library!
And then I also found out that the rounding formulas can also take a negative numbers of places, in which case it will round to the nearest 10, 100, etc:
Regards
Rambling Pete
