The application does not work. It loads all the time.
Dear @11154
Did you try to restart or clean history/ cache of your browser
Otherwise if possible to login from another machine.
If not reach out to support@coda.io
And he overloaded and cleared the history, cache, wrote to support@coda.io. With 4 PCs it does not boot.
