I am trying to create a table that updates from a master table using Cross-docs. The table updates just fine, but the comments in the comment section does not transfer over. Is there a way to do this??
Hi Jerod,
From what I know, cross-doc does not support transfer of comments. Only cell values can be transferred.
This would be helpful to sync the comments. We have a table that is read-only (cross doc) but want to engage in discussion; however those comments should reside with the “master” table. Is there a workaround?
Cross-doc comments sync is very needed feature. When could we expect an update. Or at least a formula, that could pull comments.
