Context menu section "Suggestions"
For daily work it would be helpful if in the “Suggestions” section in the context menu those blocks and actions would be suggested, which the user has just used frequently or last.
“Explore templates” could be moved to “TEMPLATES”, and “Learn Coda” should also not have top priority and be pinned here.
Normally you may work with maybe four or five block types - and these would easily find a place under “Suggestions”.
Great idea! I’ve basically had to memorize my most used suggestions (e.g. “table” and “button”).
