Problem: When I run an action via a button (marking someone present), my doc is calculating data for this column and it’s slowing down the calculation considerably.
Solution: I need to keep this data “archived” but don’t want it to be included in my calculations every time I run that action, since that data is static since it’s a different year.
What I’m trying to do to solve it: As you can see in the screenshot I’m trying to do a simple convert “toText” of the “# of Dates Attended (2018)” column to this new column to make that data static so it can be accessed but not used in calculations.
- Secondary problem caused by this solution: “toText” isn’t functioning properly, but is still keeping the new column linked to the old column.
