Creating a row using n8n?
Maybe I’m missing something, but I simply want to send form information straight into a Coda table. After I select the create a row node in n8n I choose the doc and table, but how do I see the fields in Coda to map the form answers?
It’s pretty straight forward in tools like Airtable, Smartsuite or Google Sheets. As soon a I select the destination the fields show up and I can easily map them. Any help on this? Thanks.
I am quite new to Coda myself (coming from AirTable) but it seems to me you just need to create the table with all the fields, then use a Form view of that?
