Hi -
I’m debugging the calculations of a document and in the debug view it shows "Aggregates for Deleted View @ 146ms . Can anyone tell me how to identify and remove this presumably redundant view?
Thanks
Chris
Hi -
Thanks
Chris
Hi @Chris_Joseph, it takes 12 hours after deletion for these to be removed (garbage collection) and that will happen automatically.
Thanks @mallika but I don’t think I’ve had a view called Ratings for some days now. Is there some way to manually delete aggregates or get insight into the scope of garbage collection? Alternatively - is it possible I’ve a broken reference somewhere and if so, what’s the best way to locate it?
