"Delete" in context menu for paragraphs
Image blocks, PDF blocks can be easily selected and then deleted, but paragraphs, which are also blocks, cannot be deleted as a whole, only the text of the paragraph can be selected using the cursor and then be deleted.
Therefore the option “Delete” in the context menu of a paragraph would be useful in order to be able to delete the whole paragraph with one click.
Yes, this is a simple yet clearly ergonomic and intuitive must-have !
