Displacement between lines from layuot
How can I disable users from being able to scroll through the different lines by scrolling the bottom part of the layout? thank you so much
hi @Ximo_Escamilla ,
I am sorry to say, but you cannot in this configuration. Coda does not offer any setting to hide this part of the modal.
Best, Christiaan
Thanks for answering, but then it is a problem for document security since anyone who has access to a row (even if the table is hidden) can scroll between the different rows. The only thing that occurred to me is to make a filter in the table with all the rows so that they do not appear. but it is not a clean solution. Thank you
you are right.
so far Coda did not respond to any of these observations.
you maybe interested in understanding how transparent a coda doc is:
Thank you very much, we hope that Coda can provide a solution to this soon. All the best
