Hi all,
I just wanted to post my solution to the following problem. I built a small sheet which can do help me organise my upcoming Tasmania trip with the following constraints:
- I can enter destinations and how much time I want to spend there
- I want to be able to move the destinations around and see which schedule works best, so focus on the timings is important
I encountered the following difficulties:
- it was first hard to sum up the durations I want to spend at the destinations to get an estimate how full the day is (this is basically the meat of the story - since there is no cumulative sum function [yet?])
- I encountered a floating point issue
Regarding 2
If you add the formula Duration(0,2) + Duration(0,2)
and set the display type of the column to time, it will display 3:59:59 am
and not 4:00:00am
as it should. I added Duration(0,0,0,1)
to avoid the problem. At some point they are going to fix it, the more community interest the earlier I reckon.
Regarding 1
I used the hidden column solution I found here on the forum, create a column hackyRowId
and set it to the formula
thisTable.FormulaMap(if(CurrentValue = thisRow, 1, 0)).Find(1, 0)
Then you can get the cumulative sum function as
thisTable.Filter(hackyRowId < thisRow.hackyRowId).RowToSum.Sum()
I also leave the link here for people to check my planner: Tasmania Planner
