i would like to see a new function (mode) called “Executable”. The idea is to have a kind of mode of a section where editing is restricted to defined areas. All other possibilities to edit the section is removed.
An example of usage would be a todo-list for a team, where you can only check-or-uncheck the “Checkboxes”.
cheers,
max
