Format Card on Android
It would be great to format the card that appears in the Android app so we can draw attention to the most import fields in it. The ability for bold, size and orientation to carry over to the app (or designed specifically for it)
I might also suggest that when we are entering a number into a number field it takes advantage of the numerical keyboard on the device.
Thanks so much! Keep up the awesome work!
