Hi,
I’m new on Coda.
Do you know why there’s nothing displaying into the output column?
In case you need, here’s the link to the doc: https://coda.io/d/Be-Nat_daZWOtNxHSw/_suVLF
Thanks guys for your help.
Hi,
I’m new on Coda.
i think you need to link a row of performance 2
to link to a row in audiences
- when you did Audiences.Volume
in your formula, you pulled out a collection of values (and thus the stacked icon next to it) and as its not a single value, multiplying it with a bench %
doesnt really work.
here are the steps i would suggest:
performance2
table - lets call it stageAudiences
tableif(stage = 'awareness', 0 , Bench% * Audiences.filter(stage = thisRow).Volume.first()
(or Volume.sum() - if you expect more than one values in single stage) would give you the right result.Thank you genius @Krunal_Sheth! This one works.
