Help creating 3-digit padded ID formula in Coda
Hi everyone! I’m trying to make a formula that creates an ID in this format: XXX-YYY, where XXX is the country code and YYY is the site code.
Both should always be 3 digits, even if the number is short (e.g. 9 → 009, 45 → 045).
What’s the best way in Coda to left-pad a number to 3 digits before concatenating?
hi @Elaina_Kreher ,
the left-pad is indeed a good suggestion.
what about this:
Cheers, Christiaan
This works perfectly, thank you!
Best, Elaina
