“Move line” and “Insert line” are very welcome additions to the context menu that appears when you click the 3-dot-icon. Thank you, Coda!
However, in this context, it is noticeable that the editor lacks a small feature: a selected paragraph should be automatically highlighted, indicating where exactly the paragraph begins and ends. Both for moving a paragraph, and for inserting new lines above or below it, this would be very useful.
