I want to remove this, cause I had enabled it by accident.
@Hieu_Trung try moving the cursor to the right of it, hold shift press left, this will select the control. Press delete/backspace.
Hi @Hieu_Trung,
@Johg_Ananda is correct with deleting the interactive filter itself. One more thing to double check is the actual filter on the table. If you hover over the table, at the top right you’ll see a filter icon that you can click on. If a rule is there, you can remove it.
Thanks so much for your help! I think a hover delete button would be much more intuitive.
