I noticed that the layout configuration changed after the release of forms.
It’s great to be able to duplicate layouts now.
Also I like how you implemented the visibility of fields. It’s much easier now.
What I am missing is the possibility to change the display configuration of certain fields (columns)
I don’t find, how I can change the font style and alignment.
In the old version it was possible in the top right corner, as shown in the following image, taken from
But it’s not there anymore:
Is there a way to do that?
Thanks
Jens
