How to make my notes match both a tag and a project?
Hi this is probably pretty simple but I cant get it to work.
All I want to do is have the job notes show only the job notes that belong to the project and have the same scope tag. What does that formula look like?
You have to filter the Job Notes column. If you share a (dummy) doc, it is a lot easier to share the correct formula with you.
How do I share a dummy doc?
I used this filter I got from Gemini and it seems close to what I want but it doesn’t work
Job Notes.Filter(Projects.Contains(thisRow) AND Scope Tag.Contains(thisRow.Scope Tag))
I sent the link but I dont know how to not include all the data, which is annoying because I really dont want to share this with customer data in it.
I decided to delete the link, Im not going to share my doc without keeping the data I want out.
I feel like this should be a really simple formula but nobody is responding
Sir, you are way out of line.
Joost and Christian are volunteers who help people like you in their free time. They have solved hundreds of questions, so have you considered that you are not making it easy at all?
Make a copy of your doc, remove sensitive data and share it. It’s really not that difficult.
Sorry but my doc is loaded with sensitive data and deleting it all will take a really long time.
All I want is the column to filter for both below. Thats it, I’m just really frustrated I cant get it to work and I’m not getting anywhere. This is just a sample of how frustrating of an experience coda can be for people outside of the coding world.
