I’m making a section page to basically do what a layout does, but with more flexibility, etc.
I’ve got a select control at the top for people to pick a record and have the views below it filter to records related to that value. I’d like to be able to have some buttons with the select box to allow for easy navigation between records - basically going to the next and previous value of the filter that is populating the select control. What can I do to make that happen?
