How to write docs people will actually read
Recently we’ve made a ton of updates to the writing surface in Coda, all with the goal of help you communicate more effectively and create more engaging, organized and interactive docs.
Check out this doc for a summary (and example) of how these features all come together.
What will you write in Coda? How will you use these new features to share your ideas and plans?
@nathan, congratulation: it’s an extremely well done and helpful example!
Thanks a lot: I’ll copy from it extensively!
