need some coda pack programming help:
the code im trying to run make work is:
navigator.clipboard.writeText(someParameterString);
placed inside the execute: async function(...){...}
but it doesn’t work or i can’t figure out how to or what am i lacking of… or is it possible in the first place?
document.execCommand(‘copy’) is already a depreciated web api and refrain as a solution suggestion
