Inserting horizontal rule into a formula?
I want to do something like this:
Format(Template, Horizontal rule)
Is this possible?
I also tried to build a horizontal rule into a concatenation this week, no luck.
You can do it, but you need to put the horizontal rule in a table first, and then reference it in the formula.
Awesome, thank you! :ok_hand:
