Integration between ClickUp and Coda
Hi Everyone,
Can you share information if anyone is using the integration between ClickUp and Coda? If yes > how are you being able to utilize it to the full capacity?
Let me share my scenario and pain points:
  • The goal is to track accuracy in estimations on how we work on features so that we can be more realistic in the roadmap estimations.
Im trying to pull a view from a list in clickup but Im having two problems with this:
  1. The list is not pulling all tasks that are there
  2. I can’t pull the Time Estimate and Time Tracked columns from clickup
I need (which is simple 4 fields) in coda so that I can then do relations in another table where i have my formulas.
The 4 fields I need from ClickUp are:
  1. Asignee
  2. Sprint Number
  3. Tracked Time
  4. Time Estimated
Thank you.
