Interesting filter questions
How can I create a filter to NOT include records that a flaggged as Done in the status field and the date is more than a week old?
Try along the lines of filter(Table.Done?=false AND table.date > today()-7)
(EDit to remove quotes as suggested by Max”
only dont put false in quotes
max
Hello @Chris_Hall ,
I think what you are asking for is the following code (enter this in the filter options of a table):
not(Done) && Date<today()-7
for your information:
&& is shorthand for AND
|| is shorthand for OR
