Thanks! I ended up formatting the “Width/Texture” Column as a lookup and added "factor as a related row and hid it. I don’t want to break it so Ill leave it as is but I will definitely be using these as a reference in the future. I have had the same problem multiple times but keep forgetting how I made it work. Now I can just check back in this thread, Thanks again!
