Offline and automations
I’m still trying to resolve an issue with a client who has 100+ users and they insist on using Coda on the phone app and many keep working offline, changing data that shouldn’t be changed.
I have a new possible solution but it depends on automations. If a user is using the phone app and is offline, how do automations work? If they add a row to a table that should trigger an automation will that automation que up as soon as they connect and their data is sent?
Hey @Susan_M_Davis,
Great question. Once the doc is online and the row is officially created then the automation should run as expected. Hope that helps!
Best,
Dan
