I thought I was making a button on the canvas to push a few buttons inside a table view to add a new row to a dozen records…but instead, I think I must have created an endless loop because Coda has been adding new rows everywhere and this has been going on for hours!
I thought I could solve the problem by disabling the buttons inside the table, but Coda is still actively adding news rows. Then I thought I could delete the button inside table, but that didn’t help either. Coda is still adding new rows.
Is there anyway to make the “Calculating” and addition of new rows stop?
I am going to answer my own query, in case my answer is helpful for someone else:
It finally occurred to me that I should hit the “Reload this page” button…I did it a few times, and the “Calculating” and adding of new rows stopped.
If someone reads this and can 1) validate what I did actually stopped the process (vs just being coincidence) and 2) explain why that worked if it did indeed stop the calculating, that would be awesome. And 3) a feature request is a “Stop” or “Kill” button for when processing or “Calculating” has run amok or you have some other reason you need it to stop.
