Hi everyone
We’re currently developing a Coda Pack for SurveySparrow, and we’re almost done with the implementation.
Use case:
Importing SurveySparrow survey responses into a Coda table.
We’ve reached the load testing phase, where we’re importing around 10,000 survey responses into a Coda table. However, we’re running into a blocker:
Only 100 rows are visible
Remaining rows require a plan upgrade, which is preventing us from validating the full data sync
Since this is blocking our final testing before release, we wanted to check with the community:
Is there a recommended approach for testing large data imports while developing Packs?
Is it possible to get a temporary plan upgrade or a developer account that allows higher row visibility specifically for testing purposes?
Any guidance or pointers from folks who’ve faced a similar situation would be really helpful.
Thanks in advance!
