For ‘Detail Display’ view, is there a way to change the ‘Primary’ text without it being set as a display column? This is because I have 2 tables and one look up the other and the display column has to be a UUID to automate and ensure a proper link. In this case setting a UUID as the primary text would not make sense to user as it would be some random number. Any help on this would be appreciated.
Hi @Boon_Shin_Ng,
I’m afraid this is not possible.
You can add an additional column so that the user can immediately see other relevant information for that selected row.
However, can I ask you why (and how) “set display column” would affect an automation?
Thank you.
