Problems whith a FIlter
Anyone knows why this filter don’t work
I expected that the notas column returned the complete row, not only the first column.
Thanks
Hi Luis,
[tablename].Filter()
Kind regards,
//JP
Same result
Hi,
As thisRow is a link, it needs to be converted ToText() for the formula to work.
I also had problems with this, the color coding is supporting now a lot to provide info what can be compared with each other or not. (Only the same colors, or a convertion needs to be made)
Success,
//JP
Sorry again, but I need that the column notas returns for juan the list with notes [3,7,4] . This is I want.
Hi,
Please have a look at this:
Your’s is in the section “Luis”
Kind regards,
//JP
A lot of thanks @Jean_Pierre_Traets
Is perfect
