Anyone knows why this filter don’t work
I expected that the notas column returned the complete row, not only the first column.
Thanks
PD: Sorry I’ve posted this in Suggestion Box instead here.
Thanks
“Antonio” is misspelled in [todos]
. This is a data hygiene issue. You should have ONE table that contains students in the Display column. All other tables should reference students in the [students]
table (Lookup column, Select list column, etc). This way you enter the students name ONE time and only ONE time, eliminating this particular data hygiene issue.
Thanks for the suggestion,
I posted in the Suggestion Box category by error and in that secction @Jean_Pierre_Traets gives me a solution
