Hi,
I’ve added both Quickbooks packs to some of my docs, but both are saying that the sync isn’t working. Where is the best place to get help or troubleshooting advice?
Thanks
Richard
Hi @Richard_Shears!
The community is a good place so more people can see and maybe take advantage of the solution , what is the problem you see? Could you please share a screenshot of the sync table options?
Did you follow the guide to get your company id? QuickBooks Pack: Start Here
Hi @Leandro_Zubrezki ,
Thanks for the pointer, I went back through and copied the companyId as directed and that has worked!
That’s great! I am glad it worked.
Let us know if you have any questions, bug reports or feedback about the Packs
