Same formula in different column, outputs different value
Hello! I’m running into an issue where the formula in my original Status column is returning values it shouldn’t. The formula determines layaway statuses.
To verify the logic, I split the formula into smaller parts and everything checks out. I also pasted the exact same formula into a new column and even duplicated the original column—both of those versions return the correct results. Only the original Status column shows incorrect outputs.
I can’t simply replace that column because many other parts of the doc reference Status. I’ve recorded a short video showing the issue and I’m including the full formula below.
I had to change the formula to a SwitchIf, which solved the problem, but this is not the first time this has happened to me, it occurs with If formulas.
Video:
Formula:
If(
thisRow.[Pagado♾️].ToText()=0 and thisRow.[Notas de Devolución].IsBlank(),
[En Espera➡️],
if(
thisRow.[Productos Devueltos].IsNotBlank() and thisRow.Productos.IsBlank(),
[Devolución :right_arrow_curving_left:],
If(
thisRow.Tipo = “Apartado📦” and
thisRow.[Pagado♾️] = thisRow.[Total♾️],
[Liquidado💴],
If(
thisRow.[Pagado♾️] >= thisRow.[Total♾️],
List([Pagado💵]),
If(
thisRow.[Productos Exhibidos].IsNotBlank() AND thisRow.Productos.IsBlank(),
[Exhibido :poop:],
If(
thisRow.[Pagado♾️] < thisRow.[Total♾️] and
thisRow.[Días Restantes :infinity:]< 1 and
thisRow.[Restante♾️] != 0,
[Vencido❌],
If(
thisRow.[Pagado♾️] < thisRow.[Total♾️],
List([Activo⌚]),
“a”
