[Uptd 3/23]Section outline (TOC) 7 improvements
Thanks Coda team.
Finally, Coda has “Table of content.” and it works so good.
I like Bold Head 1 and small margin as default . So I don’t need tweak it again.
and then I tweak my style about 7 improvements with Stylus (Chrome extension)
If Coda team will improve TOC with my style ,I appreciate it.
Of course , Hope design better style than mine.
1. Add “Bullet” before Head 2 and Head 3 for more clearly and quickly find hierarchies.
Issue: You can’t quickly and clearly find the hierarchies.
Solid bullet is for Head 2
Empty bullet is for Head 3
2. Hide scrollbar in TOC for looks clean.
Issue : Scrollbar is not useful and didn’t looks clean.
vs
3. Hover show and wrap Long Head Text with background
Issue : You can’t see the long Head text.
YRe8JtWoKu
4. Show the whole TOC area
Issue: you have to scroll toc again
Show the whole TOC area , So don’t need to scroll TOC again , bcz the TOC is not automatic scrolling when scroll up and scroll down document.
5. Small faded black color TOC Head 123
issue : Head 2 and Head 3 are the same color.
Solution: Use faded color for looks clear.
6 Bold and wrap text of active Head
issue :
1 . you have to hover active head for check the complete head text .
Idea: no need to hover ,and display active head text.
2. Not very obvious for looking active head text .
Q: But how margin wrap text ?
7. Hover display TOC
So no need option for TOC. Always hover display toc as default .
B07PMRZMSA
Stylus Code
  @import url('https://fonts.googleapis.com/css2?family=Noto+Sans:ital,wght@0,400;0,700;1,400;1,700&display=swap');
Author: Steve yang
Created: 2020-3-20
Updated: 3-23-2020
It works light theme, don't works darker theme.
it works all Docs and sections toc.
/** Add Bullet before Head 2 and 3**/
.KVwXaPVf:before {
	content: "\2022";
	margin-right: 6px;
._2bxE2JJg:before {
	content: "\00ba";
	margin-right: 6px;
/** Hide toc scrollbar**/
.kr-section-outline {
	--webkit-scrollbar-width-height: 0px;
/** Toc position**/
	will-change: top;
	transition: top .2s ease .2s;
	min-width: 280px;
	max-width: 480px;
	font-size: 12px;
	right: 0px;
	left: auto;
/* Hover show and wrap long text in TOC*/
._17Z50j2I {
	height: auto;
	font-size: 1.1rem;
	line-height: 1.9;
	font-family: 'Noto Sans', sans-serif;
._17Z50j2I:hover {
	background-color: rgba(180, 179, 179, .14);
	color: #1b94a2;
	overflow: visible;
	white-space: normal;
/** show the whole toc **/
._152mdk3C {
	max-height: 100vh;
/** Faded Toc Head 123**/
/** Toc Head 1, Bold Head 1 is default in Coda**/
._1Yre37ZT {
	color: rgb(100, 100, 100);
/** Toc Head 2 **/
.KVwXaPVf {
	color: rgb(10, 10, 10);
/** Toc Head 3 **/
._2bxE2JJg {
	color: rgb(130, 130, 130);
/** Active Toc Head color , bold and wrap text**/
.OdAyFSZP {
	color: #1b94a2;
	font-weight: var(--font-weight-bold);
/** Hover show TOC **/
._152mdk3C {
	opacity: 1;
._152mdk3C:hover {
	opacity: 1;
In this case ,you’ll know what is design .
Design is not only looks like , design is how it woks.
