Seems Gemini is not great and Co-pilot on Coda development
What is the best Ai - Co-pilot to use to create Coda docs
Gemini seems to get formula’s and setting wrong
I am using Claude, giving him access to the doc I am working on using the coda MCP : GitHub - orellazri/coda-mcp: MCP Server for Coda
I am working in a Claude projet specifying links to the coda documentation and proper prompt forcing it to verify each command he propose within the documentation before proposing it. It is very effective.
Wow - I’ve just started with Claude on this and it’s early but I’ve very much enjoyed the start and hopefull it will be a much superior experience to the Gemini excersise
As backup I’m using NotebookLM with Coda source and that can help double check formulas etc
