Hi there,
I’m looking to create a company-wide wiki + project/task management + goals/OKR + team meeting notes + product planning + dev mgmt + setup… inspired by August Bradley and his Notion setup My Notion Life Operating System Overview - YouTube, as well as this thread Why would you NOT try to manage all a Tech Start-Up's stuff in Coda? (so I’m conscious of some of the potential performance issues)
Should I combine everything into one doc or have separate docs for different functions/operational areas?
I’m also wanting to give access to certain part of the system to certain freelancers, which I’m assuming will be easier using a multi-doc approach, given that Coda’s permission functionality isn’t very robust?
Any other advice for approaching this task?
Thanks everyone!
Sion
