Table Results- Formula Help
I am trying to get a master table with lookups from two other tables to produce a specific output.
A+B=C.
A+D=E
I swear I am missing something silly here…
HI Tim,
Welcome to CODA.
But you must please provide a little bit more info. It can get a little tricky sometimes to link tables together, depending on the needs.
Here is a sample doc for what I am trying to replicate. I would like to use the likelihood and impact fields as drop downs which then would output a dynamically changing risk indicator based on those inputs.
I tried sharing the doc, but I can’t due to domain issues
Hi @Tim_Reed,
Have a look at this and tell me if it works for you:
Cheers!
Thanks! That will do nicely.
