Time is incorrectly treated when being pushed to notification body
Hi, I’ve noticed that if I calculate time and send it as notification path. this will not be displayed correctly.
At the same time, the same part of formula indicated exactly what I need.
The notification I get:
the formula I use:
"Last check performed at "+
totime([All morning checks].[Check time].last()) +
"by " +
[All morning checks].[Created By].last() +
". Everything is OK"
once I use formula below, time is displayed correctly:
to be sure, that’s what i see in formula field:
the same applied to mentioned user name, by the way
Never concatenate strings together with +.
Use Concatenate():
Concatenate(
  "Last check performed at ",
  totime([All morning checks].[Check time].last()),
  "by ",
  [All morning checks].[Created By].last(),
Or even better, Format():
Format(
  "Last check performed at {1} by {2}. Everything is OK",
  [All morning checks].[Check time].Last(),
  [All morning checks].[Created By].Last()
Also generally it’s a good idea to 1. .ToText() the time, and 2. dereference the actual .Name value of the person record you’re inserting:
Format(
  [All morning checks].[Check time].Last().ToText(),
  [All morning checks].[Created By].Last().Name
thank you. I’ve already found totext() function, but with Format() that looks much clearer.
