Hey Community! I hope to start sharing a few of my favorite tools/docs. They’re never perfect, so I tend not to. But I’m quite proud of some of the solutions I’ve come up with, and I’d like to share what has been useful for me either at work or in life.
First up, a Timecode Calculator
This is intended for anyone who works in video/TV/film post production. It’s a typical calculator with the added bonus that it can handle duration values and formatted timecode (a representation of duration in hours, minutes, seconds, frames, hh:mm:ss:ff).
Here’s a clip of the doc in action.
One of my favorite things about this doc is the how the framerate selection operates. With the lock button that then allows you to cycle through the available rates. I also like the Paper Tape.
The larger goal of this calculator is to be able to use it with other related tools. I imagine a doc that logs dailies and cuts, being able to select durations to send through the calculator. For example, quickly calculate the difference in length between an Editor’s Cut or a Director’s Cut. Or determine the length of a cut with certain scenes removed.
Btw, I didn’t get into the weeds of drop-frame timecodes because it’s not something I typically deal with.
As I said at the top, I know you’ll encounter some bugs or less-than-perfect behavior. It’s at a point where I should rebuild it from scratch. But who has the time! If you do, please be my guest! Hope you find something in here handy or worthwhile.
