Hello everyone.
From April, 28th, I noticed that the timeline display is not truncating the row title anymore. Before this day, the title was truncated to fit the display bar.
The image bellow shows the problem described.
Thank you.
Hello everyone.
Thank you.
Hi @Felipe_Arnhold . Thanks for reaching out and sorry to hear that you’re running into this issue. Since this seems like a possible bug, could you please file a bug report by clicking the ? in the bottom right corner of your doc and choosing “I found a bug” so that we can investigate this issue for you. Thanks in advance!
Hi @Shaina_Torgerson.
Thanks for answering. Since I am not the doc maker, I didn’t find this options, but I alredy ask to the doc maker to make the bug report.
Thanks
