Bug:
The trim method is deleting integers instead of whitespace from string created using the format method.
How to Replicate:
When inserting an integer into the beginning of a string using the format method, a subsequent application of trim will remove the integer.
Expected Behavior:
Only whitespace should be removed, not the integer.
Example: Trim Error
