Hello!
I am attempting to create a tagging system for projects. I have tried multiple versions of this to no avail.
What I’m trying to do:
I would like to create a list of tags (just a name column is needed), and a list of tests(name, and test steps). Each test will have certain tags on it. These tags are do not have to be unique to the test. Then, in a multi-select I would like to choose a set of “Tags” and pull in only unique tests.
Then in the end, you can pull in everything that needs tested based on the selected tags.
Here is a non-functional example of what I’m trying to accomplish:
