Using @Row in a Checklist
I have a table of clients.
I also tried to create a section with a daily to-do list:
[] Call @Client1 to talk about x, y, z.
[] Meet @Client2 to sign paperwork.
I originally clicked +, control, checkbox, then typed my information and that linked to the @Client just fine, so that from the to-do list I could hover over the client and see phone numbers, etc. However, manually adding the checkbox for each task was cumbersome.
So, I tried to do the checklist table mentioned in Here, but in a table my @Client wont link to the client’s information because there is additional text there.
Is there an easier way?
It creates an extra step, but just add a column. In the first column after the checkbox, enter your @client and in the new column enter the task. The order doesn’t matter if these are one-time lists (as my example below shows). If you want to build up a contact history for each client, you could up the sophistication a notch with a section that uses a button to create new to-dos just above a view of your task list that shows only today’s tasks. Then you’d have a lightweight CRM.
